  • Board index ‹ Technical - General ‹ Wheels & Tyres
alloy hub dimensions
8 posts • Page 1 of 1
Postby jpayne » Tue Oct 07, 2014 11:05 pm
Guys,
Could anyone with +10mm wider alloy hubs or who knows give me a dimension so I can determine if I have standard or wide track hubs? as wheel are rubbing on strut and need to know If I have silly wheels wrong offset hubs or both.
please.
Justin
jpayne
Re: alloy hub dimensions
Postby mickas » Thu Oct 09, 2014 9:01 pm
Which measurement? From where to where?
mickas
Postby jpayne » Thu Oct 09, 2014 11:28 pm
Yeah exactly? I'm guessing from rear bearing land to hub face? if they are +10mm it should show there.
Where are they bigger?
jpayne
Postby ozstang65 » Fri Oct 10, 2014 7:21 am
You'd want to measure from the face the rotor bolts to, to the face the wheel sits on. I have a set but they're inaccessible atm. Stephen from SMCKA might be able to help.
I could probably dig out the capri hubs and measure them, the new ones were 10mm wider.
Postby dingo_boy » Fri Oct 10, 2014 8:07 am
Justin,
I suggest sending Gartrac an email as they sell both types and are very good in providing information such as this. Otherwise I have the wider hubs on my car but the car is stored north of Adelaide and I won't be up there to visit it for a few weeks if you can wait that long.
Justin
dingo_boy
Postby ozstang65 » Fri Oct 10, 2014 6:04 pm
The standard Capri ones are 52mm from the face the rotor bolts on, to the face the wheel mounts to.
Postby jpayne » Fri Oct 10, 2014 6:23 pm
Thanks guys,
Thanks OZs
Will check mine out.
jpayne
Postby mickas » Fri Oct 10, 2014 8:14 pm
61mm from rotor bolt up face to rim bolt up face.
GRP4 fabrication hubs
mickas
Return to Wheels & Tyres
