Pinto 2.0ltr vacuum hoses
4 posts • Page 1 of 1
Postby mantaman1 » Wed Aug 28, 2013 9:14 am
Is their a diagram of the vacuum hose layout for the 2.0ltr pinto, and what can safely be removed without compromising performance.
On our dizzy there appears two vacuum hoe inlets on the vacuum advance is this correct and wher do the hoses come from. feedback.gif
mantaman1
Re: Pinto 2.0ltr vacuum hoses
Postby Miniliteman » Thu Aug 29, 2013 3:49 am
Don't know if you down under have some emission-equioment fitted as standard but over here we have the vacuumhoses for the brakebooster and the PCV-valve connected to the inlet manifold and a vacuumhose for the ignition-advance connected to the carb (no signal when throttle fully closed, signal when throttle is opened a bit).
If you have 2 vacuum-connections on the distributor then normally this distributor has a larger vacuum-canister and this was used on cars with auto-transmissions.
Miniliteman
Postby Lightning_Boy » Thu Aug 29, 2013 9:21 am
I think the vacuum canister on the distributor has one port for timing advance, and one for timing retard.
Lightning_Boy
Postby ozstang65 » Thu Aug 29, 2013 9:39 am
The Ford Workshop Manual will have the required info.
Users browsing this forum: No registered users and 5 guests
