  • Board index ‹ Technical - General ‹ Differentials
1600 diff identity
4 posts • Page 1 of 1
1600 diff identity
Postby beshy642 » Wed Apr 10, 2013 5:47 pm
Hi guys how do I tell if I have a 1600 diff or a 2ltr diff?
Steve B
Mk2 rs2000 4 door auto
beshy642
Re: 1600 diff identity
Postby marty » Wed Apr 10, 2013 8:01 pm
1600 had a 3.77 and the 2L had a 3.54 ratio diff.
If you have the diff centre out divide the number of crownwheel teeth by the number of pinion teeth and there's your ratio.
If your lucky there is a tag under one of the bolts around the diff centre.
If the diff is still together you could turn the pinion flange one rotation and count the axle rotations, I've never done it this way, I'm guessing.
little bit sideways
marty
Postby beshy642 » Wed Apr 10, 2013 8:04 pm
is the ratio pressed or printed on it anywhere?
Steve B
beshy642
Postby beshy642 » Wed Apr 10, 2013 8:05 pm
dont worry just realised what you ment about the tag
Steve B
beshy642
Return to Differentials
