  • Board index ‹ Technical - General ‹ Suspension
Gartrac quick rack and pinion into Mk2 2L Steering rack
12 posts • Page 1 of 1
Postby Damion Parkin » Wed Jan 16, 2013 9:13 am
Hi all,
I have purchased a quick rack and pinion from Gartrac with the intention of fitting it to my Mk2 2L steering rack assembly.
I pulled the 2L rack apart yesterday and found (not really to my suprise) that the thread on the rack ends from my Aussie 2L rack do not match the threads on the Gartrac rack. I didn't have a chance to look any closer as I had to head home unfortunately.
What do I need to do in order to sort this out? Do I need a capri rack? or can I buy the rack ends from somewhere and use my existing rack housing and drumsticks?
Thanks,
Damion
Mk2_2dr_2L
Damion Parkin
Re: Gartrac quick rack and pinion into Mk2 2L Steering rack
Postby Peter Knight » Wed Jan 16, 2013 1:05 pm
Hi Damion,
There are two diferent racks fitted to escorts. From memory one is Cam gears and the other is Burman I am not sure which is which but one has a removable plate opposite the input shaft and the other doesn't. you may need the other rack to what you have.
Peter.
Peter Knight
Postby mickas » Wed Jan 16, 2013 3:10 pm
You need the green tie rod ends.
mickas
Postby Damion Parkin » Wed Jan 16, 2013 3:27 pm
Hi Peter,
My rack is the rack with the removeable plate opposite the input shaft, looks exactly like the item pictured on the Gartrac site: http://gartrac.com/shop/steering-racks- ... -rack.html
Hi Mickas,
I haven't got as far as the Tie Rod end's as yet. Just trying to screw the rack end (if I can call it that) that holds the drum stick on to the rack itself.
Damion
Mk2_2dr_2L
Damion Parkin
Postby rs turbo » Wed Jan 16, 2013 3:53 pm
hi damion
mk1 has a fine thread that is imperial thread , mk2 have a course metric thread both rack ends you can get here in Australia ..
Scs automotive
6/32 Currumbin creek road
Currumbin waters 4223
0431649697 Aarron
rs turbo
Postby Damion Parkin » Thu Jan 17, 2013 7:30 am
Hi Aaron,
Cheers. I think I have a Mk1 rack amongst the spares at home, I will give it a try when I am back there in a week or two.
Mk2_2dr_2L
Damion Parkin
Postby gen mk 1rs2000 » Fri Jan 18, 2013 12:37 am
forget those "green" tie rod ends
use mk1 imperial thread ends to match capri /twink struts
mk2 rack ends have course threads & nowhere near as
fine adjustment as fine thread for toe in / out adjustments
STEVE KING mk 1 rs2000
gen mk 1rs2000
Postby gen mk 1rs2000 » Fri Jan 18, 2013 12:41 am
to make it simple
convert a mk2 rack
by putting mk1 drumsticks on the ends of the rack
not green things on the end of mk2 drumsticks
gen mk 1rs2000
Postby Damion Parkin » Fri Jan 18, 2013 12:12 pm
Hi Steve,
Ok, so I need Mk1 Rack ends.
Next question. I understand that the green tie rod ends have a metric thread to match the drumstick and a taper on the ball joint to match the capri strut?
I still use Mk2 2L struts in my car.. If I go to Mk1 Drumsticks what tie rod ends do I need? Or do I need to make the move to capri struts?
I see that I can buy Mk1 Rack ends off of ebay.. maybe I will buy these and see if the mk1 rack ends will work with the mk2 drumsticks.. baaa.gif
Cheers.
Mk2_2dr_2L
Damion Parkin
Postby Damion Parkin » Wed Apr 03, 2013 8:26 pm
Hi all,
I have bought some Mk1 rack ends that are the correct thread to suit the gartrac rack. Only thing is I need some lock nuts. Does anyone know where I can track some down?
Damion
Mk2_2dr_2L
Damion Parkin
Postby Danny M » Thu Apr 04, 2013 4:53 pm
Decent nut and bolt shop
Postby Damion Parkin » Fri Apr 05, 2013 8:51 am
Cheers Danny.
Mk2_2dr_2L
Damion Parkin
Return to Suspension
