RS Motorsport :: Classic Speed Restored • View topic - Cossie YB rods
Cossie YB rods
PostPosted: Tue Mar 28, 2006 5:12 pm
by Zakspeed
What would the rated rpm be for the std cossie rods??????
PostPosted: Wed Mar 29, 2006 9:59 pm
Albert,
I'm not sure of the factory spec for YB rods, but I've known some to turn 9000rpm. I'd think you'd be pretty safe in all but the most extreme of situations.
PostPosted: Thu Mar 30, 2006 2:09 pm
by Zakspeed
Thanks Neville.
PostPosted: Tue Apr 04, 2006 9:54 pm
Albert,
Piston, pin & ring package weight makes a difference. Packages rangeing from 450gm up to 600+gm make a big difference when multiplied by thousands of G's at TDC.
PostPosted: Sat Apr 08, 2006 3:16 pm
by Zakspeed
PostPosted: Wed Jul 18, 2007 11:50 pm
by TROUT
Um. John is sort of correct. The linear speed of a piston/rod etc increases from BDC to 90 degrees or say 9 o'clock and then decreases from that point to TDC and the corresponding change of direction.
The piston mass is not as important as the strength of the rod and gudgeon pin. We ofter see rod failure or stretching prior to the piston being lunched as it hits the head.
PostPosted: Thu Jul 19, 2007 1:10 pm
