  • Board index ‹ Technical - General ‹ Brakes
Spaced M16 Caliper and Vented Capri Disk
49 posts • Page 3 of 3 • 1, 2, 3
Re: Spaced M16 Caliper and Vented Capri Disk
Postby atd350 » Fri Mar 30, 2012 2:49 pm
exactly what capri rotor is required for spaced M16 calipers? DBAxxx?
atd350
Postby ozstang65 » Fri Mar 30, 2012 2:56 pm
Vented Discs - Plain
Capri 2.8i, EBC part = D246, same as RDA7578
Postby maxrs » Mon Jul 22, 2013 10:35 pm
Sorry to bring up an old thread.
Are the spacer washers from the vented kit 4mm thick? half the caliper spacer width?
maxrs
Postby ozstang65 » Mon Jul 22, 2013 10:36 pm
I could measure it tomorrow, but that sounds about right.
Postby maxrs » Tue Jul 23, 2013 10:05 am
That would be great if you could. Thanks Scott.
maxrs
Postby maxrs » Tue Jul 23, 2013 7:39 pm
For anyone playing at home, the spacer washers are 5.1mm wide.
maxrs
Postby gen mk 1rs2000 » Tue Jul 23, 2013 8:06 pm
mark
is that with new pads fitted
& fluid pressure ??
just try loosening off the caliper bolts after you bleed them
& even after a drive then check the caliper space to strut
just get the calipers central to the disc
STEVE KING mk 1 rs2000
gen mk 1rs2000
Postby ozstang65 » Tue Jul 23, 2013 8:17 pm
I just had a quick look at mine and i've spaced them out about 6.5mm, which was the supplied washer plus another standard washer. I did this to put the centre of the caliper inline with the centre plane of the disc. I don't recall having to do this on dad's car (Mk2 struts) bit mine are capri struts/mk2 calipers so there might be a difference because of that.
Postby Lightning_Boy » Tue Jul 23, 2013 11:20 pm
The washers should be half the additional thickness of the disc, so for (say) a 20.8mm vented disc replacing a 12.7mm solid disc, that would be half of 20.8-12.7 or 4.05mm. I say "should be" because production tolerances will mean you may want to add or subtract a bit in order to center the caliper over the disc exactly, although in practice even that may not matter.
Lightning_Boy
Previous
Return to Brakes
