  • Board index ‹ Technical - Engines ‹ Pinto 1.6 / 1.8 / 2.0 / 2.?
Camshaft Selection
7 posts • Page 1 of 1
Camshaft Selection
Postby Damion Parkin » Mon Oct 06, 2014 5:56 pm
Hi All,
I am planning on building a pinto in near future and I am hoping that some of you can help me to choose a suitable camshaft.
The bottom end is pretty standard, just 60thou over and balanced. I have two heads to choose from both with 45.5 inlet and 38.1 exhaust valves (from memory). One has large ports with a redline inlet manifold ported to suit and the other has more sensible looking sized ports.
I have twin 45mm webers with 36mm chokes and a new set of genie extractors.
I am hopeful of making 150+ HP however, most importantly I want it to be something that is not too much of a pig to drive on the street - this will be an weekend driven road car.
I have been considering something like a Kent RL30 cam, does anyone have any experience with these? I did use a Kent FR32 in essentially a standard pinto a few years back and it was very boring (despite all the hype in Classic Ford mag at the time), so I am a little weary of cam choice this time round.
In addition, it would also be good to find a contact in SE qld that can assist in setting up the head - I have killed many cam lobes on pintos over the years, so I would like to do it right this time. A recommendation for a good weber tuner would be great as well.
Cheers,
Damion
Mk2_2dr_2L
Damion Parkin
Re: Camshaft Selection
Postby Miniliteman » Tue Oct 07, 2014 6:48 am
Hi,
what is your 1st gear ratio and also what is the rear axle ratio?
Grtz, Leon.
Miniliteman
Postby Damion Parkin » Tue Oct 07, 2014 11:46 am
Hi Leon,
It is a standard 2L box, 3.65:1 1st gear from memory. Diff currently is a 3.54:1, however we may end up using a 3.77:1.
In addition to my questions above, what sort of compression ratio should I be aiming for?
Thanks.
Mk2_2dr_2L
Damion Parkin
Postby Miniliteman » Wed Oct 08, 2014 5:39 am
With the std gearbox I would suggest you should get a not too lairy cam as the drop in revs when shifting up is quite big.
FR33 is a good cam for a roadcar with twin 45's.
Personally I would also say that the Kent GTS1 is the ultimate roadcam but I haven't tried that myself
CR depends also on fuel used but don't overdo it with cast pistons.
10.3 : 1 is a safe bet.
With 36 mm chokes use F11 tubes, 180 air jets, 55F6 idlejets and 145 mains with the FR33 or 150 mains with the GTS1.
Miniliteman
Postby Damion Parkin » Wed Oct 08, 2014 6:48 am
Cheers. Yeah, the GTS 1 looks like a viable candidate as well.
Mk2_2dr_2L
Damion Parkin
Postby ratta tat tat » Wed Oct 08, 2014 11:10 pm
I've heard good things about the kent ultimate road cam from someone with a very good reputation with pintos.
ratta tat tat
Postby Damion Parkin » Thu Oct 23, 2014 7:57 am
Thanks ratta tat tat.
Mk2_2dr_2L
Damion Parkin
Return to Pinto 1.6 / 1.8 / 2.0 / 2.?
Users browsing this forum: No registered users and 4 guests
