  • Board index ‹ Technical - Engines ‹ Pinto 1.6 / 1.8 / 2.0 / 2.?
oil pickup gasket or not
Postby dek » Wed Jan 08, 2014 9:40 pm
I am just putting a different sump and pickup back on a motor which has been apart for a while and can not remember if there was a gasket between the pick up and the oil pump?
dek
Re: oil pickup gasket or not
Postby SportsSedanSteve » Thu Jan 09, 2014 7:42 am
Can only speak about Pinto 2L, in which case there def is a gasket. Plus ensure you put it on the right way as the oil hole is offset to the bolt holes. I learnt this one the hard way.
SportsSedanSteve
Return to Pinto 1.6 / 1.8 / 2.0 / 2.?
