Page 10 of 11
Re: The Rebuild Begins
Thu Aug 15, 2013 9:12 am
Thu Aug 15, 2013 6:29 pm
New question. The dyno bloke just rand and said the sump is leaking from a pinhole in the braze where the scavenge pipe meets the sump. What sort of meterial would be good to plug this? Silicon type sealant or something more like a JB Weld or metal putty?
Also, and of more worry, is that he says the Peterson two piece tank is leaking where the halves join. There is a rubber seal recessed into the bottom part of the tank that I know was no damaged previously. Is there any other reason why the tank might leak there? I thought the clamp was done up tight but maybe I need to lean on the spanner more? Danny, you ever had issues with yours???? Who in Oz sells new seals? If I cannot get one are there any other alternative sealing methods? I have the 2.0 gallon 19.5 x 6 Part #08-0026
The last issue is that the Omex rev limiter is cuaing a missfire lower in teh rev range. Disconnecting it got rid of the problem. Not sure whether to buy a new one, troubleshoot the current one or just bin it altogether for next week's Targa (5 days till scrutineering)?
Fri Aug 16, 2013 12:05 am
With the sump you could use an epoxy resin (liquid metal etc) if you can get it clean enough as I would be a little hesitant using a silicone as it can create havoc when you go to weld it up later. I have seen Blutac, yes Blutac packed on to the hole to block (works on fuel tanks too)
The tank, yes you can disturb the seal and it pops out of the groove and leaks and no matter how tight you do it up it leaks. Performance Wholesale sell replacement seals which will get you out of the jam but I just go down the seal shop and buy a bag of them for the price of one.
With the rev limiter just leave it off as I never ran a limiter on my pintos
Fri Aug 16, 2013 8:50 am
by stuart
My brother uses this at work its about $40 from tradelink
http://www.rapidfixaustralia.com.au/
Fri Aug 16, 2013 8:05 pm
OK. Sump plugged. New o-ring in oil tank (was pinched and split).
124 killer wasps at the rear wheel apparently. Means nothing to me really.
This motor has much higher oil pressure than the last one. The engine builder tells me it will be due to the decent clearances and that up to 80psi is good. The last motor witht he same oil pump built up to full pressure more gradually than this motor which hits 75-80psi by a few thousand revs. Again, builder said that isnt an issue. The dyno bloke and builder both agree that I need to ditch the electric oil pressuregauge I have and put a mechanicla VDO in. Comments?
Fri Aug 16, 2013 8:27 pm
by SportsSedanSteve
40 psi at idle is good and you should have 80-90 psi by 3-5000. Relief spring should open then and not develop any more pressure. Hoping to be in town for the night stage so may catch up with you then.
Fri Aug 16, 2013 8:30 pm
by SportsSedanSteve
Fri Aug 16, 2013 10:39 pm
After the night stage we will all be in the pavillion for a while so anybody who wants to meet feel free to pop in!!! (spanners optional!)
Sat Aug 17, 2013 7:09 am
by Cam
124kw at the wheels is an awesome result! Should be a lot fun!
Sat Aug 17, 2013 5:56 pm
WTF? why are you using an electric gauge for?
Get a VDO or a Stack mechanical gauge
The bigger the clearances the less pressure is made but the bigger the clearances the more power that can be made
If it's got 124kw it'd be interesting to see mine on there as that's better than what we see
Sat Aug 17, 2013 6:29 pm
Yeah i take dyno figures with a pinch of salt personally.
Sat Aug 17, 2013 7:15 pm
Wait till you drive it and make your mind up then
Sat Aug 17, 2013 7:35 pm
I have....and boy it feels strong!!!!
Thu Aug 22, 2013 10:37 pm
Fri Aug 23, 2013 7:27 am
Cheers Kingy.
So far so good. 8th overall in classics! Post more tonight....
Sun Aug 25, 2013 6:21 pm
Sun Aug 25, 2013 9:37 pm
by Cam
Sorry to hear you didn't make it to the finish. Sounds like you had a lot of fun though, and the early results are very encouraging.
At least that nice new engine is ok!
Sun Aug 25, 2013 9:58 pm
Tue Aug 27, 2013 8:48 pm
Wed Aug 28, 2013 1:37 pm
Well done Oz.the evolution needs to continue on all those bloody little things. but an encouraging result and possible result.
Too bad there are so few events to practice in. What is your next event
Justin
