ESCORT MK1 AND MK2 NEW PARTS
Postby errolleslie » Tue Dec 23, 2014 4:30 am
Hi All,
Prices in Sterling
NOS Ford
Escort Mk2 Bonnet Stay White Clip 3.00
Escort Mk1 or Mk2 Courtesy Lights Switches 40.00
Escort Mk2 Bonnet Adjustment Rubbers 15.00
Escort Mk2 Bonnet Cable Clamp 20.00
Escort Mk2 Wiper Arm Caps 30.00 for both
Escort Mk2 Brake Pipe Clips Bulkhead 3 Pipe Ones 15.00 for both
Escort Mk2 Brake Pipe Clip Servo (Steel One) 6.00
Escort Mk2 Single Fuel Pipe Clips 2.00 each
Escort Mk2 Bonnet Stay Grommet 3.00
Escort Mk2 Single Steel Brake Pipe Clip Bulkhead 6.00
Escort Mk2 ATE Servo Return Valve 25.00
Pinto Rocker Cover Cap 20.00
RS Wheel Center Caps (Plastic Type fitted with either x-pack or standard. Have to be sealed from behind to hold) 25.00
Escort Mk2 Double Fuel Pipe Clips (Steel Ones) 2.00 each
Escort Mk2 Single Fuel Clips 2.00 Each
Escort Mk2 Grey Speedo Cable Clip 5.00
Escort Mk2 Seat Adjustment Centers 15.00
Escort Mk2 Clutch Cable Sleeve (Yellow) 10.00
Escort Mk2 Bootlid Landing Rubbers (Ones Closes to the Rear Panel) 10.00
Escort Mk2 Window Winder Inserts 10.00
Escort Mk2 Water Hose Clamps 8.00
Escort Mk2 Altisimmo Rear Bumper Lights 30.00
Escort Mk2 Strut Top Nuts 8.00
Escort Mk2 Strut Top Bolts 3.00 Each
Escort Mk2 Double Fuel Pipe Clips (Ones above rear axle) Black Set of 6 is 20.00
Escort Mk2 Double Fuel Pipe Clips (Along Axle) White Price is 3.00 each
Escort Mk2 Fuse Box Cover 20.00
Escort Mk2 Altisimmo Fog Light Unit 40.00 (Has slight marks)
Escort Mk2 Servo Bulkhead Grommet 40.00
Escort Mk2 Black Boot Badge 3 Pin Type 40.00
Escort Mk1 Rear Bonnet Landing Rubber 25.00
Escort Mk1 Window Winders 25.00
Escort Mk1 Early Trottle Pedal 15.00
Escort Mk2 Chrome Boot Lock With Gasket 40.00
Escort Mk2 Clear Washer Bottle Cap 20.00
Escort Mk2 Grill Clips 2.00
Escort Mk1 Chrome Front Rings 80.00
Escort Mk2 Door Pins 3.00 Each
Escort MK2 Passenger Door Skin 300.00
Escort Mk2 Light Blue Oval Badges 35.00 Each
Escort MK2 ATE Servo Cap 70.00
Escort Pinto Rocker Cover Single Clips 10.00 For A Aet
Escort Mk2 Boot Lock Catch 30.00
Escort Mk2 Bonnet Catch Grommet (Black) 12.00 Each
Remanufactured Parts
Steering Wheel Centers Mint 20.00 (Ford Oval Type)
RS Spare Wheel Strap 25.00
RS Bulkhead Flap and Fixing Plate 8.00
Battery Clamp Bracket 10.00
Cam Cover Stickers 1300, 1600, 2000, 2100 3.00
Pin Strip Stickers Around Rear Lenses 11.00
Custom Badge 5.00
Heater Control Graphic RHD Early and Late Type and LHD Ones 8.00
Colour Code Sticker 4.00 (Just need colour of your car)
Seat Belt Press Buttons 5.00 Include green safety stickers
Engine Crossmember Base Plate 18.00
Convert Kit Crossmember Standard to RS Spec 25.00
MK1 RS Wind Deflector 25.00
Mk1 RS Crossmember Base Plate 15.00
Heater Element Sticker 10.00
RS2000 Rear Bumper End Fixing Clamps 10.00 (Stainless Steel)
Washer Bottle Bracket 10.00 (3 Lung Type)
ATE Sticker 5.00
RS2000 Boot Carpet 90.00 (Original Ford Material)
Mk2 Jack Bag 30.00
Servo Pipe - Slam Panel Clips 11.00
RS2000 Center Console Bottom Bracket 11.00
RS2000 Center Console Top Bracket 9.00
Alternator Decal RS2000 5.00
Escort Mk2 Rear Shelve (Between Rear Seat and Boot Area) 35.00
Escort MK2 Boot Lock Gasket 8.00
RS2000 Bumper End Caps Set of Four 18.00
Thanks,
Errol
errolleslie
Re: ESCORT MK1 AND MK2 NEW PARTS
Postby geoffeteson » Mon Nov 09, 2015 7:25 am
I am looking for the clamp at the end nearest the bonnet release mechanism. If that is the item that appeared on your post and you still have it I would be interested in buying it.
geoffeteson
Return to For Sale
