FULL LIST OF CURRENT STOCK OF ESCORT PARTS
1 post • Page 1 of 1
Postby errolleslie » Mon Mar 18, 2013 7:36 pm
HELLO ALL
LIST OF NOS AND NEW REMANUFACTURED PARTS I HAVE AVAILABLE FOR ESCORT MK1 AND MK2.
POSTAGE ON TOP OF THE PRICES BUT I WILL SEND AS CHEAP AS POSSIBLE.
NOS Ford
Bonnet Adjustment Rubbers 18.00
RS2000 Inner Wing Relay 45.00
Bonnet Cable Clamp 14.00
Wiper Arm Caps 12.00 for both
Brake Pipe Clips Bulkhead 3 Pipe Ones 15.00 for both
Brake Pipe Clip Servo (Steel One) 6.00
Single Fuel Pipe Clips 2.00 each
Bonnet Stay Grommet 3.00
Single Steel Brake Pipe Clip Bulkhead 6.00
ATE Servo Return Valve 25.00
Pinto Rocker Cover Cap 20.00
RS Wheel Center Caps (Plastic Type fitted with either x-pack or standard. Have to be sealed from behind to hold) 35.00
Double Fuel Pipe Clips (Steel Ones) 2.00 each
Grey Speedo Cable Clip 5.00
Airbox Clamps 5.00
Seat Adjustment Centers 15.00
Clutch Cable Sleeve (Yellow) 30.00
Washer Bottle Pump 30.00
Yellow Servo Clip 20.00 (Secondhand)
Bootlid Landing Rubbers (Ones Closes to the Rear Panel) 10.00
Fuel Filler Neck Rubber 30.00
Window Winder Inserts 10.00
Water Hose Clamps 8.00
Altisimmo Rear Bumper Lights 30.00
Strut Top Nuts 8.00
Double Fuel Pipe Clips (Ones above rear axle) Black Set of 6 is 20.00
Double Fuel Pipe Clips (Along Axle) White Price is 3.00 each
Remanufactured Parts
RS Spare Wheel Strap 19.00
RS Bulkhead Flap and Fixing Plate 5.00
Battery Clamp Bracket 8.00
Cam Cover Stickers 3.00
Pin Strip Stickers Around Rear Lenses 11.00
Custom Badge 5.00
Heater Control Graphic 8.00
Colour Code Sticker 4.00 (Just need colour of your car)
Seat Belt Press Buttons 5.00 Include green safety stickers
Engine Crossmember Base Plate 16.00
Convert Kit Crossmember Standard to RS Spec 18.00
MK1 RS Wind Deflector 25.00
Mk1 RS Crossmember Base Plate 15.00
Heater Element Sticker 10.00
Bulkhead Pad Top Clips 8.00 (Stainless Steel)
RS2000 Rear Bumper End Fixing Clamps 10.00 (Stainless Steel)
Washer Bottle Bracket 10.00 (3 Lung Type)
ATE Sticker 5.00
RS2000 Boot Carpet 90.00 (Original Ford Material)
Jack Bag 30.00 (Will be available soon)
Servo Pipe - Slam Panel Clips 10.00
Thanks,
Errol
errolleslie
Return to For Sale
