massive list of escort mk1 and mk2 new parts
4 posts • Page 1 of 1
Postby errolleslie » Wed May 27, 2015 1:50 am
HELLO ALL,
lights
mk2 nos rear light lenses altisimmo set 220.00
mk2 nos front indicator lenses set 60.00
mk2 reproduction rear light seals set 45.00
mk2 nos rs2000 inner wing relay 50.00
mk2 altisimmo rear bumper lights set 50.00
mk2 nos fog light unit (has light marks) 40.00
mk1 chrome front rings 80.00
interior
mk2 as new deep dish 3 spoke steering wheel
with nos rs center cap 350.00
mk2 nos rs center cap 70.00
mk2 nos 3 spoke ford oval center cap 60.00
mk2 mint e spoke ford oval center cap 20.00
mk2 repro rs2000 european rs center cap 46.00
mk2 rs2000 custom badge 5.00
mk2 press button seat decals 5.00
mk2 reproduction rs2000 4 speed gearknob 52.00
mk2 repro scheel seat tilt forward lever bezel set 24.00
mk2 repro scheel seat forward lever set 36.00
mk2 nos rs2000 recaro seat tilt forward lever set 25.00
mk2 nos seat adjustment centers set 15.00
mk1 or mk2 courtesy switches set 40.00
mk1 or mk2 nos courtesy switches set 80.00
mk2 heater control decal early or late type 8.00
mk2 heater element rear window decal 10.00
mk1 nos trottle pedal 15.00
mk2 repro trottle pedal 22.00
mk2 repro rs2000 center console top bracket 10.00
mk2 repro rs2000 center console bottom bracket 10.00
mk1 nos window winder handles set 25.00
mk2 nos door pins each 3.00
mk2 nos door lock knob set 10.00
mk2 nos window winder inserts set 10.00
mk1 nos cigar ligher 45.00
mk2 repro parcel shelf 100.00
boot area
mk1 or mk2 repro spare wheel strap 25.00
mk2 repro rear shock absorber hats set 16.00
mk2 repro rear firewall partition panel 35.00
mk1 or mk2 repro jack bag 30.00
mk2 repro rs2000 carpet (original ford material) 90.00
mk2 colour code decal 3.00
mk2 boot floor/shackle bolt access grommet set 22.00
mk2 nos boot seal 45.00
mk2 nos boot landing grommets set 10.00
exterior
mk2 nos ford light blue oval badges 45.00
mk2 nos black boot badge 40.00
mk2 nos boot lock chrome 40.00
mk2 repro center caps with rs decals set 35.00
mk2 nos black door handles set 200.00
mk2 repro boot lock gasket 8.00
mk2 repro rs2000 bumper end caps set 18.00
mk2 repro rs2000 bumper end fixing clamps set 10.00
mk1 repro wiper wind deflector 25.00
mk2 pin strips around rear lenses set 11.00
mk2 nos wiper end caps set 30.00
mk2 nos washer jets set 30.00
mk2 nos mirror gasket 5.00
mk2 nos plastic wheel nut cover each 3.00
mk2 grill clips each 3.00
engine bay
mk2 nos washer bottle cap 15.00
mk2 repro washer bottle bracket 10.00
mk2 nos engine crossmember 220.00
mk2 repro engine crossmember base plate 20.00
mk2 repro engine crossmember rs convert kit 25.00
mk2 repro main wire loom/bulkhead grommet 18.00
mk2 repro steering column/bulkhead grommet 18.00
mk2 repro bonnet bump stops set of four 25.00
mk2 nos bonnet rear bump stop 15.00
mk2 nos bonnet adjustment rubbers set 18.00
mk1 repro bonnet bump stops set of four 18.00
mk1 repro bonnet adjustment rubbers 15.00
mk2 repro handbrake linkage/backing plate dust boot 25.00
mk2 repro speedo cable/bulkhead grommet 11.00
mk2 repro bonnet release cable/inner guard grommet 11.00
mk2 repro bell housing clutch boot 20.00
mk2 repro rear valence panel grommet kit 28.00
mk2 repro rs2000 oil line bulkhead grommet 11.00
mk2 repro brake booster servo rod/bulkhead grommet 22.00
mk2 repro rs2000 aluminium bellhousing grommet each 11.00
mk2 ate decal 5.00
mk2 alterantor decal 5.00
mk2 cam decal 1600, 2000 or 2100 3.00
mk2 repro servo pipe/slam panel clips set 11.00
mk2 nos ate master cylinder cap 70.00
mk2 nos ate servo return valve 25.00
mk2 nos steel servo clip 6.00
mk2 nos pinto rocker cap 20.00
mk2 nos pinto rocker cover single clips set 10.00
mk2 repro pinto rocker cover double clip 5.00
mk2 repro rs bulkhead flap and fixing plate 8.00
mk2 repro battery clamp bracket 10.00
mk2 nos bonnet spring 30.00
mk2 nos bonnet catch 25.00
mk2 nos bonnet stay white clips 3.00
mk2 nos bonnet stay white grommet 3.00
mk2 nos bonnet stay black grommet 12.00
mk2 nos bonnet cable clamp 20.00
mk2 nos brake pipe clips 3 pipe ones set 15.00
mk2 nos brake pipe bulkhead clip 6.00
mk2 nos steel double fuel pipe clips each 2.00
mk2 nos single fuel pipe clip each 2.00
mk2 nos grey fuel clip 5.00
mk2 nos yellow clutch cable sleeve 10.00
mk2 nos water hose clamps set 8.00
mk2 nos strut top nuts set 8.00
mk2 nos strut top bolts each 3.00
mk2 nos double fuel pipe clips (above rear axle) set of 6 18.00
mk2 nos double white axle fuel clips each 3.00
mk2 nos fuse box 20.00
mk1 nos rear landing rubber 25.00
mk2 nos rs2000 full gasket set 40.00
mk2 nos pinto overflow pipe 20.00
THANKS,
ERROL
errolleslie
Re: massive list of escort mk1 and mk2 new parts
Postby Lightning_Boy » Wed May 27, 2015 7:37 pm
What's the unit of currency - Au $ or £?
Lightning_Boy
Postby Miniliteman » Sat May 30, 2015 8:22 pm
Could even be Euro's as he's from Ireland!
But think that's all GBP.
Miniliteman
Postby errolleslie » Sun Jun 07, 2015 6:59 pm
Hello,
Yes prices are in sterling.
Thanks,
Errol
errolleslie
Return to For Sale
