RMs Car, parts n stuff.
Howdy,
My car is set up to run in Improved Production, racing, here in OZ,
http://www.iprasa.mx.com.au/
Which allows limited modifications to these rules.
http://www.iprasa.mx.com.au/rules.htm
All mods to car are done by myself, other than engine machining.
Older Specs.
It has a pinto, German 2 liter head,T 10 block. 38 & 43mm valves, twin 45s, 38 chokes, TRW 11.5 pistons, head planed to get 12.4:1. That put out 180 on engine dyno and 130 Rear wheel HP on chassis dyno. [depending on who u believe]
1600 cc struts with adjust height. 420 lb springs, 22 mm front bar, 3.5 of neg, 5 of castor. Capri competition wet strut inserts. Capri 2.8I rotors Volvo 4 piston calipers, DS 3000 pads. No booster. 13/16" master cylinder.
English axle with 4.44, clutch plate diff. 16mm rear bar. Koni shocks there. 125 lb springs. No traction bars.
4 speeder with SC/CR 2.39 first gear set. Rose quick shifter.
Couple o sets of wheels. 2 sets of 13 x 7 old A008rs on one,
A032s on other and a set 13 x 7/8 with F2/3 slicks on them, a s they become available.
2004
Currently same engine, with better? head. Different manifold. Same carbs
4.5 degrees neg 7 degrees of castor.
Capri struts, koni RX7 inserts, Volvo 4 spots, BMW rotors.
More modifications as I get to them and money is available.
Some pics and vids.
Some Videos at the bottom of page 5
Older Specs.
2004
Some pics and vids.
