  • Board index ‹ Technical - General ‹ Electrical, Ignition & Engine Mngmt
1600 Alternator
4 posts • Page 1 of 1
1600 Alternator
Postby ozstang65 » Fri May 03, 2013 2:01 pm
Hi all, I'm chasing a replacement alternator for the 1600 in the racecar. I'd like to get one with a bit bigger pulley, as light as possible and preferably only with the battery connection (bolt terminal) and indicator light only. Fabricating brackets can be accommodated if required. Only has to run ignition, fuel pump and brake lights so there's not many Amps needed.
Any recommendations on where to get one from would also be helpful.
Cheers,
Scott
Re: 1600 Alternator
Postby mickas » Fri May 03, 2013 8:47 pm
There is a mob is brissy. DJ auto electrics. Should be able to get a cheap enough bosch unit.
I will be back at work next week I can get a price through Ashdown ingrams...?
mickas
Re: 1600 Alternator
Postby stuart » Sun May 05, 2013 1:28 am
I just installed a daihatsu charaide alternator nice and small http://westfield-world.com/daihatsu_alternator.html pretty easy to install as well
stuart
Re: 1600 Alternator
Postby ozstang65 » Sun May 05, 2013 10:15 pm
Thanks guys, I might check out one of the option of one of the smaller ND units.
Return to Electrical, Ignition & Engine Mngmt
