Tue Dec 22, 2009 9:04 pm
by Noono
Most articles i've read on installing battery in boot recommend using circuit protection - but guess not needed if careful with installation/insulation.
Found this article
http://autospeed.com.au/cms/A_110776/article.html
uses a c/b from jaycar which is supposedly good for 150amp for 10 secs
I'm interested in any comments
Cheers Gregg
Tue Dec 22, 2009 9:52 pm
.............watts
amps = ____
............ Volts
Depending on watt starter u have
1400
____
12 = 117 AMPS
or
750
___
12 = 62.5 AMPS
IMHO the biggest killer will be the joints. which are easy to find via temperature.
Wed Dec 23, 2009 12:52 pm
Issue wull be starter current, and whether the engine fires before exceeding the trip curve.
A trip curve is how much current vs time dispalyed in graph form.
150A for 10s might be, 200A instant trip, 100A for 20sec or 30A continuously.
I once measured an Escort bosch starter at about 250A.
Even at 150A you have a great big welder / plasma cutter just waiting to get going.
