1600 diff identity
PostPosted: Wed Apr 10, 2013 5:47 pm
by beshy642
Hi guys how do I tell if I have a 1600 diff or a 2ltr diff?
Re: 1600 diff identity
PostPosted: Wed Apr 10, 2013 8:01 pm
by marty
1600 had a 3.77 and the 2L had a 3.54 ratio diff.
If you have the diff centre out divide the number of crownwheel teeth by the number of pinion teeth and there's your ratio.
If your lucky there is a tag under one of the bolts around the diff centre.
If the diff is still together you could turn the pinion flange one rotation and count the axle rotations, I've never done it this way, I'm guessing.
PostPosted: Wed Apr 10, 2013 8:04 pm
by beshy642
is the ratio pressed or printed on it anywhere?
PostPosted: Wed Apr 10, 2013 8:05 pm
by beshy642
dont worry just realised what you ment about the tag
