RS Motorsport :: Classic Speed Restored • View topic - pinto water pumps
Page 1 of 2
pinto water pumps
PostPosted: Sat Apr 24, 2010 9:51 pm
by joe84
PostPosted: Sat Apr 24, 2010 10:04 pm
PostPosted: Sat Apr 24, 2010 11:55 pm
PostPosted: Sun Apr 25, 2010 9:50 am
by joe84
PostPosted: Sun Apr 25, 2010 9:57 am
PostPosted: Sun Apr 25, 2010 6:15 pm
PostPosted: Sun Apr 25, 2010 6:56 pm
by joe84
PostPosted: Sun Apr 25, 2010 7:21 pm
by kizza
PostPosted: Sun Apr 25, 2010 9:03 pm
by Clayton
PostPosted: Mon Apr 26, 2010 9:45 am
PostPosted: Mon Apr 26, 2010 1:39 pm
by joe84
PostPosted: Mon Apr 26, 2010 8:46 pm
by Clayton
PostPosted: Mon Apr 26, 2010 10:21 pm
PostPosted: Mon Apr 26, 2010 11:41 pm
PostPosted: Tue Apr 27, 2010 7:44 am
PostPosted: Tue Apr 27, 2010 8:17 am
PostPosted: Tue Apr 27, 2010 1:37 pm
Do you keep the standard water pump pulley or go a bit bigger for the higher revving motors?
PostPosted: Tue Apr 27, 2010 4:15 pm
Bigger
PostPosted: Wed Apr 28, 2010 12:20 pm
by joe84
alright i had a quick play with the plate on the back of the impellor, i had a water pump gasket lying around , and had some 1mm steel used a 75mm hole saw to cut the plate , then marked out where the veins (claytons idea) were drilled small holes on all of them tack welded on and ground it down, so it was all done for nothing so it's no loss if it doesn' t do much , something i would of changed if doing it again is use something like 1.6mm steel or stainless as i turned the welder up slighty to make sure it would weld to the thicker impellor but as you can see it started blowing a hole but it's inline with the impellor so it should affect it, but all up you could probably do it in around 1 - 2 hrs from pulling the water pump off too puttin it back on
PostPosted: Wed Apr 28, 2010 12:23 pm
by joe84
might be a little while before i test it because i need new tyres one is dead flat
