  • Board index ‹ Technical - General ‹ Fuel System - Carbies, EFI etc
twin 45 webbers
3 posts • Page 1 of 1
twin 45 webbers
Postby mario » Sun Oct 29, 2017 11:42 am
Hi all
Max hp on a 2 litre pinto with twin 45mm webers and 40 mm chokes cheers mario. thumbup.gif
mario
Re: twin 45 webbers
Postby jpayne » Mon Oct 30, 2017 5:30 am
Welcome max!.
What is the maximum power experienced on a Pinto with twin 45mm weber carburettors utilising 40mm chokes?
depends on if you ask an australian or an englishman. One will say 200Hp the other will say, whats been done to the engine, whats its condition, if standard maybe 130Hp.
JP
jpayne
Re: twin 45 webbers
Postby Paul » Wed Dec 13, 2017 1:23 pm
agree with JP with cams and porting 130hp -145hp if its a proper rs2000 9.5c/r? pinto motor and not the cortina/escort 7.5 c/r low compression motor.
I was regularly reving my RS2000 stock bottom end to 9500rpm and the only ill affects i had was I was streching my valve stems
and ran out of room to adjust rockers. <Young and stupid is the saying.
Delorto's over webbers all day long.
Paul
Return to Fuel System - Carbies, EFI etc
