  • Board index ‹ Technical - General ‹ Fuel System - Carbies, EFI etc
NO FUEL PRESSURE QUERY?
16 posts • Page 1 of 1
Postby ulsterman » Sun Nov 03, 2013 6:01 pm
Guys, I am having an issue on my Anglia trying to get any Fuel Pressure.
I have 2 Red Top "Works" Facet Fuel Pumps 5 PSI linked together but only running the one. The other is a backup pump only.
The Fuel leaves the swirlpot at the tank via -6 stainless braided lines. It goes to the 2 Pre Filters and then into the Pumps. From the Pumps it goes directly to the webers.
From the webers it returns to the Holley Regulator "IN" connection before going through the "OUT" port back to the fuel tank.
I have the Pressure Gauge on the "IN" port at the Holley regulator.
I have replaced both the Gauge (Oil Filled Face) and the Regulator even though they are both brand new to start with.
The adjustment on the Regulator is via a screw at the top that is adjusted in for more pressure. No matter what way it is screwed there is no Pressure registering on the Gauge. I have even swopped the IN and OUT lines but it makes no difference.
Any ideas guys would be greatly appreciated.
Rob
ulsterman
Re: NO FUEL PRESSURE QUERY?
Postby Danny M » Sun Nov 03, 2013 6:26 pm
Ya Goose
The Holley Red regulator needs to go before the Webers as they aren't designed for the return
Also if you fitted a decent fuel pump instead of the pommie crap you'd only need one!
Postby ulsterman » Sun Nov 03, 2013 6:37 pm
Good one Danny
Already tried the regulator on the feed line
No difference
ulsterman
Postby ulsterman » Sun Nov 03, 2013 6:48 pm
Danny those Facet Pumps aren't pommie they are made in the USA
The details supplied with the Holley reg show the reg fitted between the pump and the carby on a single feed line
On a double carby it clears shows the reg fitted between the last carby and the fuel tank on the return line
ulsterman
Postby MK1_Oz » Sun Nov 03, 2013 7:21 pm
Pumps in series or parallel? If later you need non-return valves I suspect.
Postby wayovermyhead » Sun Nov 03, 2013 7:38 pm
I assume you are 100% sure you are using the bypass version of the regulator? there are two versions of that one and only the BP one will work between the carbs and the tank.
Secondly you say you have the return line connected to the 'out' port. If I remember correctly, on the BP style regulater there is a port marked 'return' or just 'ret'. The out port should supply the carbs if used before them, or can take a pressure gauge if used after.
The pressure gauges fail very regularly so even though you have tried two, maybe you have just been very unlucky??
Hope that's helps some, it's all from memory from some time ago without seeing exactly what you have we are all just speculating a bit.
Llewellyn
wayovermyhead
Postby ulsterman » Sun Nov 03, 2013 7:46 pm
Thanks guys
I have tried the reg on both the feed line going from the pumps to the carbies and also from the carbies to the tank return
No reading either way
I will check but i think the reg has only an IN and 2 OUT ports
Rob
ulsterman
Postby Paul T » Tue Nov 05, 2013 12:58 pm
Since I can't see it mentioned do you actually have fuel flow?
Might be worth putting up a picture of the tank and pumps.
Paul T
  • Website
Postby ulsterman » Tue Nov 05, 2013 1:35 pm
Thanks guys
The bypass reg fixed it on the return line back to the tank
ulsterman
Postby mickas » Tue Nov 05, 2013 7:07 pm
Did I not say that when I was pi$$ed the other day...
mickas
Postby ulsterman » Tue Nov 05, 2013 7:12 pm
The lips were moving but the words werent legible
ulsterman
Postby Danny M » Tue Nov 05, 2013 7:47 pm
Robin for sidedraughts you run both the outlets with one to each carburettor
Try disconnecting one of the pumps. Are you using a hand held pressure gauge or one mounted off the regulator
Ring me if you want
Postby mickas » Tue Nov 05, 2013 8:38 pm
[quote="Ring me if you want[/quote]
Do you answer his calls...
mickas
Postby ulsterman » Tue Nov 05, 2013 9:04 pm
Thanks Danny
Got it sorted
Rob
ulsterman
Postby Danny M » Wed Nov 06, 2013 9:15 am
He's not a rude prick like you Mick :-)
Postby mickas » Wed Nov 06, 2013 11:14 am
:drinkers:
mickas
Return to Fuel System - Carbies, EFI etc
