  • Board index ‹ Technical - General ‹ Brakes
Alloy Hub Torque Setting
9 posts • Page 1 of 1
Postby Mk2RS+R32 » Wed Feb 13, 2013 10:40 am
Hi Guys,
Whats the torque setting for the bolts to attach my alloy front hubs to the alloy bell (used with the AP Disk) and should I use Loctite?
For info the Bell to Disk is 14NM.
Mk2RS+R32
Re: Alloy Hub Torque Setting
Postby gen mk 1rs2000 » Thu Feb 14, 2013 12:57 am
dont use loctite
its lets go with heat
best method i reckon is to
tighten bolts while hot to
corect tourqe setting for the size & grade of bolt
& if you want to do properly
drill the heads & lockwire them
ive heard all the crap about
if you tighten them properly
they SHOULDNT??? come undone
but
when lockwired
they CAN NOT !!! come undone
see the difference ???
STEVE KING mk 1 rs2000
gen mk 1rs2000
Postby mickas » Thu Feb 14, 2013 2:09 pm
Loctite come loose? I have seen it used on caliper bolts for years and never seen a failure...
mickas
Postby joe84 » Thu Feb 14, 2013 8:11 pm
If it's threaded into alloy, i would run at 3/4 std torque spec
joe84
Postby Danny M » Fri Feb 15, 2013 8:07 am
The torque setting is for the fastener to reach it's correct yield to do it's job so torque the bolts to what ever the Ford manual says and yes lock wire them as the heat from the brakes can create havoc with Loctite
Postby Mk2RS+R32 » Mon Feb 18, 2013 1:00 pm
The Alloy hubs and Bells come from GRP4 Fab along with bolts. No torque numbers for the bolt. I'll do what's been suggested here.
Mk2RS+R32
Postby Danny M » Tue Feb 19, 2013 5:00 pm
I did my Gartrac ones up to what ever the Ford manual said
Postby gen mk 1rs2000 » Tue Feb 19, 2013 7:35 pm
THE FORD MANUAL SAYS
AFTER YU STRIP THE THREAD
BACK IT OFF HALF A TURN
gen mk 1rs2000
Postby Danny M » Tue Feb 19, 2013 8:09 pm
You're a twat Steve! LOL!!!!!
Return to Brakes
